Zum Hauptinhalt wechseln
Sony VAIO PCG-F360 Speaker Panel Replacement
Was du brauchst
  1. Sony VAIO PCG-F360 Speaker Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 2, Bild 1 von 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 3, Bild 1 von 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 4, Bild 1 von 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: Schritt 5, Bild 1 von 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: Schritt 5, Bild 2 von 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: Schritt 5, Bild 3 von 3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 6, Bild 1 von 3 Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 6, Bild 2 von 3 Sony VAIO PCG-F360 Speaker Panel Replacement: Schritt 6, Bild 3 von 3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
Abschluss
Hannah Millea
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-5, Calaway Spring 2014 Mitglied von UMass Dartmouth, Team 3-5, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 155
