Einleitung
Removing the back panel requires taking of the top panel first. Then, you must remove four more screws on the back.
Was du brauchst
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Remove the top panel of the DVD Player by:
Sliding the top panel backwards.
Gently lifting the back of the top panel up.
Remove the back panel by:
Lifting up on the back panel.
Pulling the back panel backwards from the DVD player.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
