Was du brauchst
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Lift the keyboard gently from the side closest the screen.
Pull out the ribbon connecting the keyboard to the laptop.
Remove the upper half of laptop and place bottom half in the center of your workspace.
Remove the one 2.00mm phillips screw.
Remove the ribbon cable connecting the USB ports to the motherboard.
Remove the two 2.5mm phillips screws holding the spring retainer for the heat sink.
Remove the two 4.0mm phillips screws holding the fan in place.
Remove the fan power connector.
Rotate the locking screw holding the CPU in, counter clockwise 180 degrees.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
When I replaced the old battery by the new one ,a message "4 minute to full charge ".some one told me there is a process to do .what is this process???
