Zum Hauptinhalt wechseln
Kodak EasyShare M2008 Lens Replacement
Was du brauchst
  1. Kodak EasyShare M2008 Lens Replacement, Battery: Schritt 1, Bild 1 von 2 Kodak EasyShare M2008 Lens Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Lens Replacement: Schritt 2, Bild 1 von 2 Kodak EasyShare M2008 Lens Replacement: Schritt 2, Bild 2 von 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Lens Replacement, Device Casing: Schritt 3, Bild 1 von 3 Kodak EasyShare M2008 Lens Replacement, Device Casing: Schritt 3, Bild 2 von 3 Kodak EasyShare M2008 Lens Replacement, Device Casing: Schritt 3, Bild 3 von 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Lens Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 4, Bild 3 von 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Lens Replacement: Schritt 5, Bild 1 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 5, Bild 2 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 5, Bild 3 von 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Lens Replacement, Lens: Schritt 6, Bild 1 von 3 Kodak EasyShare M2008 Lens Replacement, Lens: Schritt 6, Bild 2 von 3 Kodak EasyShare M2008 Lens Replacement, Lens: Schritt 6, Bild 3 von 3
    • Remove screws from front silver panel.
  7. Kodak EasyShare M2008 Lens Replacement: Schritt 7, Bild 1 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 7, Bild 2 von 3 Kodak EasyShare M2008 Lens Replacement: Schritt 7, Bild 3 von 3
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  8. Kodak EasyShare M2008 Lens Replacement: Schritt 8, Bild 1 von 1
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brian
252 Reputation
2 Anleitungen geschrieben
New Mexico State, Team 1-2, Easley Spring 2014 Mitglied von New Mexico State, Team 1-2, Easley Spring 2014
NMSU-EASLEY-S14S1G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 283
