Zum Hauptinhalt wechseln
TomTom ONE Back Cover Replacement
Was du brauchst
  1. TomTom ONE Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Back Cover Replacement: Schritt 2, Bild 1 von 2 TomTom ONE Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Back Cover Replacement: Schritt 5, Bild 1 von 1
    • As you can see, the battery and the speaker are still attached to the device and must be removed.
    • Using the spudger, carefully pry out both the battery and the speaker.
    • When taking out the speaker, the entire plastic shock mounting casing will come out.
    • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
  6. TomTom ONE Back Cover Replacement: Schritt 6, Bild 1 von 1
    • Once the battery and the speaker are removed, you now only have the back cover!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Trevor Foster
145 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-7, Maness Spring 2010 Mitglied von Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 6,934
