Zum Hauptinhalt wechseln
Acer Iconia A110 Speaker Replacement
Was du brauchst
  1. Acer Iconia A110 Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Iconia A110 Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Speaker Replacement: Schritt 2, Bild 1 von 3 Acer Iconia A110 Speaker Replacement: Schritt 2, Bild 2 von 3 Acer Iconia A110 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Speaker Replacement: Schritt 3, Bild 1 von 3 Acer Iconia A110 Speaker Replacement: Schritt 3, Bild 2 von 3 Acer Iconia A110 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  4. Acer Iconia A110 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Acer Iconia A110 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
    • Two 2.0 mm screws (with the bigger head)
    • Four 2.5 mm screws (with the smaller head)
  5. Acer Iconia A110 Speaker Replacement: Schritt 5, Bild 1 von 2 Acer Iconia A110 Speaker Replacement: Schritt 5, Bild 2 von 2
    • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
    • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
    • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
  6. Acer Iconia A110 Speaker Replacement: Schritt 6, Bild 1 von 2 Acer Iconia A110 Speaker Replacement: Schritt 6, Bild 2 von 2
    • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
    • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrea
757 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-42, Maness Spring 2014 Mitglied von Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 736
