Zum Hauptinhalt wechseln
Samsung Galaxy S Blaze Power Button Replacement
Was du brauchst
  1. Samsung Galaxy S Blaze Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Power Button Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S Blaze Power Button Replacement: Schritt 3, Bild 2 von 2
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Power Button Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy S Blaze Power Button Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy S Blaze Power Button Replacement: Schritt 4, Bild 3 von 3
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
Abschluss
Dustin
1.213 Reputation
6 Anleitungen geschrieben
Ein Kommentar
Please can someone help me with samsung t769 power way on the board ?
Nyawu Ebenezer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,199
