Zum Hauptinhalt wechseln
HP G72 Hard Drive Replacement
Was du brauchst
  1. HP G72 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 HP G72 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 HP G72 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
  2. HP G72 Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP G72 Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP G72 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Loosen the two Phillips 2.5×6.0 captive screws that secure the hard drive cover to the computer.
    • The cover is snapped in by some clips. Use a plastic opening tool on both sides to remove the cover.
  3. HP G72 Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP G72 Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP G72 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the cover
    • Remove the four Phillips M2.5x5.0 screws
    • Disconnect the hard drive cable from the system board.
  4. HP G72 Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP G72 Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP G72 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the hard drive from the hard drive bay
    • Remove the hard drive cable from the drive.
    • Remove the four (two on either side) Phillips M3.0×4.0 screws that secure the hard drive bracket to the hard drive
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
784.220 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
558 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 7,248
