Einleitung
This guide will walk you through the process of replacing a dead or dying battery in a Samsung Gear 2.
Was du brauchst
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Use the pointed side of the spudger to remove the small, orange battery cable.
26 weitere Nutzer:innen haben diese Anleitung absolviert.
15 Kommentare
Where can one find said replacement battery. I had it on in less than a meter of water for less than 30 minutes and water was able to get in. Even though I did not subject it to its supposed limitations I am fairly certain that best buy or samsung will check the water indicator paper and tell me that it was my fault. I have taken it apart and gotten it all dried out. It will come on and function just fine and then when i unplug it it will turn off after a minute or so. At any rate, I would like to replace my battery but need to find one first.
Where can I find a battery I have looked everywhere including Ebay and Amazon?
I am looking for a battery also mine is very bad after 1 year. Were you able to find one?
