Einleitung
The battery is located inside the tablet part of the device. The plastic backing must be removed before the battery can be accessed.
Was du brauchst
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Insert the opening tool into the seam of the tablet casing and gently pry upwards.
With a little force, you will feel the clips release.
Slide the tool along all four edges of the tablet, making sure that all the clips are released.
Gently pull back the yellow transparent plastic covering on top of the battery connection port.
Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
Remove the battery by slowly peeling the battery away from the connected side.
The adhesive on the back will pull away from the battery.
68 weitere Nutzer:innen haben diese Anleitung absolviert.
22 Kommentare
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
Hi christian! How did you solve this problem? That happened to me too...
Part number is C12N1320. They are available from a variety of sources.
