Zum Hauptinhalt wechseln
HP dv5-1125nr Hard Drive Replacement
Was du brauchst
  1. HP dv5-1125nr Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 HP dv5-1125nr Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP dv5-1125nr Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP dv5-1125nr Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP dv5-1125nr Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Loey
1.676 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 2,051
