Zum Hauptinhalt wechseln
KDDI Kyocera A5521K Front LCD Screen Replacement
Was du brauchst
  1. KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 1, Bild 1 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 1, Bild 2 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 1, Bild 3 von 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the screws using a Y0 screwdriver.
  3. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 3, Bild 1 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 3, Bild 2 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Use the Y0 screwdriver to remove the screws.
  5. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 5, Bild 1 von 2 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 6, Bild 1 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 6, Bild 2 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Separate the faceplate from the phone.
  7. KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: Schritt 7, Bild 1 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: Schritt 7, Bild 2 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: Schritt 7, Bild 3 von 3
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  8. KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 8, Bild 1 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 8, Bild 2 von 3 KDDI Kyocera A5521K Front LCD Screen Replacement: Schritt 8, Bild 3 von 3
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
Abschluss
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,502
