Zum Hauptinhalt wechseln
HP dv5-1125nr Keyboard Replacement
Was du brauchst
  1. HP dv5-1125nr Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Keyboard Replacement, Hard Drive: Schritt 3, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Keyboard Replacement: Schritt 5, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Keyboard Replacement: Schritt 6, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Keyboard Replacement: Schritt 7, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr Keyboard Replacement, RAM: Schritt 8, Bild 1 von 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  9. HP dv5-1125nr Keyboard Replacement: Schritt 9, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the RAM cover to reveal the module's underneath.
  10. HP dv5-1125nr Keyboard Replacement: Schritt 10, Bild 1 von 3 HP dv5-1125nr Keyboard Replacement: Schritt 10, Bild 2 von 3 HP dv5-1125nr Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
  11. HP dv5-1125nr Keyboard Replacement, Keyboard: Schritt 11, Bild 1 von 1
    • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
  12. HP dv5-1125nr Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
  13. HP dv5-1125nr Keyboard Replacement: Schritt 13, Bild 1 von 1
    • Unscrew the 4mm Phillips screw inside the hard drive bay.
    • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
  14. HP dv5-1125nr Keyboard Replacement: Schritt 14, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Locate the hole in between the hard drive and RAM compartments.
    • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
    • Unscrew the 4mm Phillips head screw from this hole.
  15. HP dv5-1125nr Keyboard Replacement: Schritt 15, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 15, Bild 2 von 2
    • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
    • You may need to use the opening tool on both sides of the cover.
    • Be careful not to break the ribbon cables under the cover.
  16. HP dv5-1125nr Keyboard Replacement: Schritt 16, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
  17. HP dv5-1125nr Keyboard Replacement: Schritt 17, Bild 1 von 1
    • Dislodge the keyboard to access the underside.
    • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
  18. HP dv5-1125nr Keyboard Replacement: Schritt 18, Bild 1 von 2 HP dv5-1125nr Keyboard Replacement: Schritt 18, Bild 2 von 2
    • Locate the ribbon cable connection between the keyboard and motherboard.
    • Pull upwards on the small black bar to release the ribbon cable and remove it.
    • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
  19. HP dv5-1125nr Keyboard Replacement: Schritt 19, Bild 1 von 1
    • The keyboard is now ready for replacement.
Abschluss
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Loey
1.676 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 2,381
