Zum Hauptinhalt wechseln
LeapFrog LeapPad2 Explorer Back Camera Replacement
Was du brauchst
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 2, Bild 1 von 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 2, Bild 2 von 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 2, Bild 3 von 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: Schritt 3, Bild 1 von 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 4, Bild 1 von 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 4, Bild 2 von 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 4, Bild 3 von 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: Schritt 5, Bild 1 von 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: Schritt 5, Bild 2 von 2
    • Locate the back camera below the game cartridge.
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 6, Bild 1 von 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 6, Bild 2 von 2
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 7, Bild 1 von 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 7, Bild 2 von 2
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
Abschluss
Nupur Garg
867 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-10, Regan Spring 2014 Mitglied von Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,193
