Zum Hauptinhalt wechseln
Lenovo IdeaTab A2109 Battery Replacement
Was du brauchst
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaTab A2109 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaTab A2109 Battery Replacement: Schritt 3, Bild 2 von 2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaTab A2109 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaTab A2109 Battery Replacement: Schritt 5, Bild 2 von 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle
581 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-19, Regan Spring 2014 Mitglied von Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 8,278
