Zum Hauptinhalt wechseln
Lenovo IdeaTab A2109 IO Board Replacement
Was du brauchst
  1. Lenovo IdeaTab A2109 IO Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 2, Bild 2 von 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 3, Bild 2 von 2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 4, Bild 2 von 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 5, Bild 2 von 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 IO Board Replacement, System Board: Schritt 6, Bild 1 von 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: Schritt 6, Bild 2 von 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: Schritt 6, Bild 3 von 3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 7, Bild 1 von 3 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 7, Bild 2 von 3 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 7, Bild 3 von 3
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 9, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 9, Bild 2 von 2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 10, Bild 1 von 3 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 10, Bild 2 von 3 Lenovo IdeaTab A2109 IO Board Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: Schritt 11, Bild 1 von 2 Lenovo IdeaTab A2109 IO Board Replacement, IO Board: Schritt 11, Bild 2 von 2
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 IO Board Replacement: Schritt 12, Bild 1 von 1
    • Once the screws are out, use the tweezers to pull the board straight out.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian
565 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-19, Regan Spring 2014 Mitglied von Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Mitglieder
15 Anleitungen geschrieben
6 Kommentare
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - Antwort
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - Antwort
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - Antwort
Excelente guía. Muchas gracias.
Larry Pacheco - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 4,923
