Einleitung
We will be teaching you the proper way to disassemble your Sony NEX-5R so that you can replace your front case. This will be helpful to those that have damaged the front case and are looking to fix it by themselves.
Was du brauchst
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Use the spudger to raise the corner of the case from the camera.
One component of the front case should now be separate from the camera.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Can anybody tell me where I can purchase the replacement part used in this video - Regards
Chris
