Zum Hauptinhalt wechseln
Samsung Galaxy S Blaze Display Assembly Replacement
Was du brauchst
  1. Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: Schritt 1, Bild 1 von 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: Schritt 1, Bild 2 von 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy S Blaze Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
  5. Samsung Galaxy S Blaze Display Assembly Replacement, Display Assembly: Schritt 5, Bild 1 von 1
    • Gently remove the 2 ribbon cables as shown.
    • Connect the new screen to the main motherboard just the same way it was connected before.
    • Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Dustin
1.213 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 1,174
