Zum Hauptinhalt wechseln
Sony NEX-5R Rear Case Replacement
Was du brauchst
  1. Sony NEX-5R Rear Case Replacement, Front Case: Schritt 1, Bild 1 von 2 Sony NEX-5R Rear Case Replacement, Front Case: Schritt 1, Bild 2 von 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Rear Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Rear Case Replacement: Schritt 3, Bild 1 von 2 Sony NEX-5R Rear Case Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Rear Case Replacement, Rear Case: Schritt 4, Bild 1 von 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Rear Case Replacement: Schritt 5, Bild 1 von 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Rear Case Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Rear Case Replacement: Schritt 7, Bild 1 von 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Rear Case Replacement: Schritt 8, Bild 1 von 2 Sony NEX-5R Rear Case Replacement: Schritt 8, Bild 2 von 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Rear Case Replacement: Schritt 9, Bild 1 von 1
    • The back case should now be removed and look like this.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emily Trujillo
1.114 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-9, Regan Spring 2014 Mitglied von Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 31
Insgesamt: 2,542
