Zum Hauptinhalt wechseln
Disassembling Nokia 3100b Microphone
Was du brauchst
  1. Disassembling Nokia 3100b Microphone, Battery: Schritt 1, Bild 1 von 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Microphone: Schritt 2, Bild 1 von 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Microphone, SIM Card: Schritt 3, Bild 1 von 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Microphone: Schritt 4, Bild 1 von 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Microphone, Microphone: Schritt 5, Bild 1 von 1
    • Press the black tabs to release the front cover from the phone.
  6. Disassembling Nokia 3100b Microphone: Schritt 6, Bild 1 von 1
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  7. Disassembling Nokia 3100b Microphone: Schritt 7, Bild 1 von 1
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  8. Disassembling Nokia 3100b Microphone: Schritt 8, Bild 1 von 1
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  9. Disassembling Nokia 3100b Microphone: Schritt 9, Bild 1 von 1
    • Note the location of the microphone.
  10. Disassembling Nokia 3100b Microphone: Schritt 10, Bild 1 von 1
    • Use tweezers to remove the microphone from the phone's base.
  11. Disassembling Nokia 3100b Microphone: Schritt 11, Bild 1 von 1
    • The microphone is now removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 29-64, Johann Spring 2010 Mitglied von Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 2,094
