Zum Hauptinhalt wechseln
Nook HD Motherboard Replacement
Was du brauchst
  1. Nook HD Motherboard Replacement, Case: Schritt 1, Bild 1 von 3 Nook HD Motherboard Replacement, Case: Schritt 1, Bild 2 von 3 Nook HD Motherboard Replacement, Case: Schritt 1, Bild 3 von 3
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
  2. Nook HD Motherboard Replacement: Schritt 2, Bild 1 von 2 Nook HD Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
  3. Nook HD Motherboard Replacement: Schritt 3, Bild 1 von 3 Nook HD Motherboard Replacement: Schritt 3, Bild 2 von 3 Nook HD Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
  4. Nook HD Motherboard Replacement: Schritt 4, Bild 1 von 3 Nook HD Motherboard Replacement: Schritt 4, Bild 2 von 3 Nook HD Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
  5. Nook HD Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Nook HD Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • There are three ribbon cable connections that you must disconnect in order to remove the motherboard.
    • The first of these connections is small black - grey plastic connection housing.
    • Use the plastic opening tool to pull the black part of the ribbon cable housing up and away from the circuit board.
    • Carefully pull the ribbon cable out of the plastic connection housing.
  6. Nook HD Motherboard Replacement: Schritt 6, Bild 1 von 1
    • The second of these connections is a small white - tan plastic connection housing.
    • Use the plastic opening tool to pull the tan part of the housing up and away from the circuit board.
  7. Nook HD Motherboard Replacement: Schritt 7, Bild 1 von 1
    • The final connection is a large orange ribbon cable that connects to an entirely separate circuit board.
    • Use the plastic opening tool to gently pry the cable away from the smaller circuit board as to disconnect the cable from the pins.
  8. Nook HD Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use the T5 torx screwdriver to remove the four 2.5 millimeter screws that attach the motherboard to the back plate.
  9. Nook HD Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently pull the motherboard straight off of the back plate.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Gregory Irwin
856 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-43, Maness Spring 2014 Mitglied von Cal Poly, Team 3-43, Maness Spring 2014
CPSU-MANESS-S14S3G43
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
what is the name of the connector in step 7?
mark miller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,563
