Zum Hauptinhalt wechseln
Conair Infiniti Pro Model 259NP Fan Grill Replacement
Was du brauchst
  1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 2, Bild 1 von 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 3, Bild 1 von 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 3, Bild 2 von 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 3, Bild 3 von 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: Schritt 4, Bild 1 von 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: Schritt 4, Bild 2 von 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 5, Bild 1 von 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 5, Bild 2 von 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 5, Bild 3 von 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Grill: Schritt 6, Bild 1 von 1
    • Hold the front panel of the hair dryer by the nozzle facing upward.
  7. Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 7, Bild 1 von 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: Schritt 7, Bild 2 von 2
    • Using your index finger push the fan grill down with moderate force.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Timothy Lo
1.172 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 10-58, Amido Spring 2014 Mitglied von Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,267
