Zum Hauptinhalt wechseln
HP dv5-1125nr Motherboard Replacement
Was du brauchst
  1. HP dv5-1125nr Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Motherboard Replacement, Hard Drive: Schritt 3, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Motherboard Replacement: Schritt 5, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Motherboard Replacement: Schritt 6, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Motherboard Replacement: Schritt 7, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr Motherboard Replacement, WLAN Card: Schritt 8, Bild 1 von 1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr Motherboard Replacement: Schritt 9, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr Motherboard Replacement: Schritt 10, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
  11. HP dv5-1125nr Motherboard Replacement, Disk Drive: Schritt 11, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement, Disk Drive: Schritt 11, Bild 2 von 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  12. HP dv5-1125nr Motherboard Replacement: Schritt 12, Bild 1 von 3 HP dv5-1125nr Motherboard Replacement: Schritt 12, Bild 2 von 3 HP dv5-1125nr Motherboard Replacement: Schritt 12, Bild 3 von 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
  13. HP dv5-1125nr Motherboard Replacement, CMOS Battery: Schritt 13, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement, CMOS Battery: Schritt 13, Bild 2 von 2
    • Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
  14. HP dv5-1125nr Motherboard Replacement: Schritt 14, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 14, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Locate the CR2032 watch battery
    • Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
  15. HP dv5-1125nr Motherboard Replacement: Schritt 15, Bild 1 von 1
    • The CMOS battery is now removed from your system.
  16. HP dv5-1125nr Motherboard Replacement, RAM: Schritt 16, Bild 1 von 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  17. HP dv5-1125nr Motherboard Replacement: Schritt 17, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the RAM cover to reveal the module's underneath.
  18. HP dv5-1125nr Motherboard Replacement: Schritt 18, Bild 1 von 3 HP dv5-1125nr Motherboard Replacement: Schritt 18, Bild 2 von 3 HP dv5-1125nr Motherboard Replacement: Schritt 18, Bild 3 von 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
  19. HP dv5-1125nr Motherboard Replacement, Keyboard: Schritt 19, Bild 1 von 1
    • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
  20. HP dv5-1125nr Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
  21. HP dv5-1125nr Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Unscrew the 4mm Phillips screw inside the hard drive bay.
    • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
  22. HP dv5-1125nr Motherboard Replacement: Schritt 22, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 22, Bild 2 von 2
    • Locate the hole in between the hard drive and RAM compartments.
    • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
    • Unscrew the 4mm Phillips head screw from this hole.
  23. HP dv5-1125nr Motherboard Replacement: Schritt 23, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 23, Bild 2 von 2
    • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
    • You may need to use the opening tool on both sides of the cover.
    • Be careful not to break the ribbon cables under the cover.
  24. HP dv5-1125nr Motherboard Replacement: Schritt 24, Bild 1 von 1
    $5.49
    Kaufen
    • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
  25. HP dv5-1125nr Motherboard Replacement: Schritt 25, Bild 1 von 1
    • Dislodge the keyboard to access the underside.
    • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
  26. HP dv5-1125nr Motherboard Replacement: Schritt 26, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 26, Bild 2 von 2
    • Locate the ribbon cable connection between the keyboard and motherboard.
    • Pull upwards on the small black bar to release the ribbon cable and remove it.
    • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
  27. HP dv5-1125nr Motherboard Replacement: Schritt 27, Bild 1 von 1
    • The keyboard is now ready for replacement.
  28. HP dv5-1125nr Motherboard Replacement, Display: Schritt 28, Bild 1 von 3 HP dv5-1125nr Motherboard Replacement, Display: Schritt 28, Bild 2 von 3 HP dv5-1125nr Motherboard Replacement, Display: Schritt 28, Bild 3 von 3
    • Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
  29. HP dv5-1125nr Motherboard Replacement: Schritt 29, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 29, Bild 2 von 2
    • Locate the two ribbon cable connectors that attach the speaker assembly to the motherboard.
    • Using your fingers, carefully detach the ribbon cables from the motherboard by pulling them straight out on the connector.
  30. HP dv5-1125nr Motherboard Replacement: Schritt 30, Bild 1 von 1
    • Remove the speaker assembly from the keyboard tray.
  31. HP dv5-1125nr Motherboard Replacement: Schritt 31, Bild 1 von 1
    • Locate the large display ribbon connector near the upper left corner of the keyboard tray and remove the ribbon by pulling straight out on the connector.
  32. HP dv5-1125nr Motherboard Replacement: Schritt 32, Bild 1 von 1
    • The display should now be loose, but make sure to remove all ribbon connectors before attempting to take off the display.
    • Locate the two final ribbon connectors for the display on the motherboard and remove them similarly by pulling straight outward on the connectors.
    • You are now free to remove the display from the computer.
  33. HP dv5-1125nr Motherboard Replacement, Motherboard: Schritt 33, Bild 1 von 1
    • Remove the three 3mm Phillips head screws on the top of the frame using the Phillips #00 screwdriver.
  34. HP dv5-1125nr Motherboard Replacement: Schritt 34, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 34, Bild 2 von 2
    • Using a plastic opening tool, carefully pry off the top plastic cover by lifting it up at the seam at various points around the edge, then remove it completely.
  35. HP dv5-1125nr Motherboard Replacement: Schritt 35, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 35, Bild 2 von 2
    • Remove the two 2mm screws on the bottom right of the motherboard using the Phillips #00 screwdriver.
  36. HP dv5-1125nr Motherboard Replacement: Schritt 36, Bild 1 von 2 HP dv5-1125nr Motherboard Replacement: Schritt 36, Bild 2 von 2
    • Using the Phillips #00 screwdriver, unscrew the spring-release fasteners on the modem card and remove it from the board.
    • Do not try to remove the modem card from the laptop, it is still attached to the modem connector on the underbody.
  37. HP dv5-1125nr Motherboard Replacement: Schritt 37, Bild 1 von 1
    • Remove the power cable and two ribbons on the top right side of the board.
    • These ribbons can be removed by simply pulling to the right of the connector.
  38. HP dv5-1125nr Motherboard Replacement: Schritt 38, Bild 1 von 1
    • Remove the ribbon on the bottom left of the board.
  39. HP dv5-1125nr Motherboard Replacement: Schritt 39, Bild 1 von 1
    • Remove the one 3mm Phillips screw on the bottom left corner of the board using the Phillips #00 Screwdriver.
  40. HP dv5-1125nr Motherboard Replacement: Schritt 40, Bild 1 von 1
    • Make sure to ground yourself to a metal object before attempting to remove the motherboard. Static charge build-up is dangerous to electronics and may ruin your motherboard if not properly grounded.
    • Remove the motherboard from the laptop body, being careful to keep the modem board from dislodging itself.
    • Your motherboard is now removed.
Abschluss
To reassemble your device, follow these instructions in reverse order. Ensure the ribbons and plastic connectors are placed in the correct orientation.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Loey
1.676 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
I hv Hp dv 5 1125nr laptop it display problems I m not getting cpu or graffic card
Vijay - Antwort
Problema con hp dv5 1050es, no arranca cuando pulso botón de encendido
Nacho - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 4,479
