Zum Hauptinhalt wechseln
Motorola V60i Keypad Replacement
Was du brauchst
  1. Motorola V60i Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola V60i Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Keypad Replacement: Schritt 2, Bild 1 von 2 Motorola V60i Keypad Replacement: Schritt 2, Bild 2 von 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Keypad Replacement, Back Plate: Schritt 3, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Keypad Replacement: Schritt 4, Bild 1 von 2 Motorola V60i Keypad Replacement: Schritt 4, Bild 2 von 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Keypad Replacement: Schritt 5, Bild 1 von 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Motorola V60i Keypad Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Gently lift logic board from back plate.
  7. Motorola V60i Keypad Replacement: Schritt 7, Bild 1 von 2 Motorola V60i Keypad Replacement: Schritt 7, Bild 2 von 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  8. Motorola V60i Keypad Replacement, Keypad Sensor: Schritt 8, Bild 1 von 2 Motorola V60i Keypad Replacement, Keypad Sensor: Schritt 8, Bild 2 von 2
    • Once logic board is removed lift the green keypad sensor for the front plate.
  9. Motorola V60i Keypad Replacement, Keypad: Schritt 9, Bild 1 von 2 Motorola V60i Keypad Replacement, Keypad: Schritt 9, Bild 2 von 2
    • To replace keypad buttons, lift off white tray containing buttons.
Abschluss
Cal Poly, Team 30-40, Garner Spring 2010 Mitglied von Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 1,859
