Zum Hauptinhalt wechseln
Sanyo VPC-T850 Photo Array Device Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sanyo VPC-T850 Photo Array Device Replacement, Disassembling Sanyo VPC-T850 Outer Casing: Schritt 1, Bild 1 von 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: Schritt 2, Bild 1 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: Schritt 2, Bild 2 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: Schritt 2, Bild 3 von 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: Schritt 3, Bild 1 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: Schritt 3, Bild 2 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: Schritt 3, Bild 3 von 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Sanyo VPC-T850 Photo Array Device Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Sanyo VPC-T850 Photo Array Device Replacement: Schritt 5, Bild 1 von 1
    • Separate the rear panel from the rest of the camera.
  6. Sanyo VPC-T850 Photo Array Device Replacement: Schritt 6, Bild 1 von 2 Sanyo VPC-T850 Photo Array Device Replacement: Schritt 6, Bild 2 von 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Sanyo VPC-T850 Photo Array Device Replacement: Schritt 7, Bild 1 von 2 Sanyo VPC-T850 Photo Array Device Replacement: Schritt 7, Bild 2 von 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: Schritt 8, Bild 1 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: Schritt 8, Bild 2 von 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: Schritt 8, Bild 3 von 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
  9. Sanyo VPC-T850 Photo Array Device Replacement, Disconnect the Ribbon: Schritt 9, Bild 1 von 2 Sanyo VPC-T850 Photo Array Device Replacement, Disconnect the Ribbon: Schritt 9, Bild 2 von 2
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  10. Sanyo VPC-T850 Photo Array Device Replacement, Remove LCD Screen: Schritt 10, Bild 1 von 1
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
  11. Sanyo VPC-T850 Photo Array Device Replacement, Photo Array Device: Schritt 11, Bild 1 von 1
    • Remove the two screws holding the photo array.
  12. Sanyo VPC-T850 Photo Array Device Replacement: Schritt 12, Bild 1 von 3 Sanyo VPC-T850 Photo Array Device Replacement: Schritt 12, Bild 2 von 3 Sanyo VPC-T850 Photo Array Device Replacement: Schritt 12, Bild 3 von 3
    • Remove the foam from the top of the wire connector.
    • Gently remove the plastic connector in the same way as the previous connector of the same type.
    • Lift the connector from the side with the ribbon cable in it.
    • Using the spudger, gently push from the right side.
Abschluss
Jonathan Yau
26 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 27-95, Amido Spring 2010 Mitglied von Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,074
