Zum Hauptinhalt wechseln
Dell Inspiron One 2020 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron One 2020 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
Abschluss
35 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler
4.920 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
25 Anleitungen geschrieben
3 Kommentare
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Antwort
Good Job, short and sweet and easy to follow
schmidtrg - Antwort
Really useful information thank you.
Jessie Colon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 79
Insgesamt: 35,723
