Zum Hauptinhalt wechseln
Disassembling Dell Inspiron One 2020 Back Cover
Was du brauchst
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: Schritt 1, Bild 1 von 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: Schritt 1, Bild 2 von 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: Schritt 1, Bild 3 von 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: Schritt 2, Bild 1 von 3 Disassembling Dell Inspiron One 2020 Back Cover: Schritt 2, Bild 2 von 3 Disassembling Dell Inspiron One 2020 Back Cover: Schritt 2, Bild 3 von 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: Schritt 3, Bild 1 von 3 Disassembling Dell Inspiron One 2020 Back Cover: Schritt 3, Bild 2 von 3 Disassembling Dell Inspiron One 2020 Back Cover: Schritt 3, Bild 3 von 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Abschluss
28 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler
4.920 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
25 Anleitungen geschrieben
Ein Kommentar
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 33,800
