Einleitung
This guide will show you how to replace your keyboard.
Was du brauchst
Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
Push back the screen until it is flat with the laptop.
Gently remove the clips that connect the panel to the screen.
Use the Phillips #1 screwdriver to remove the two screws.
Gently pry the keyboard from the laptop using the blue iFixit opening tool.
Slowly lift the keyboard away from the laptop.
Remove the ribbon that connects to the laptop.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
