Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein PlayStation Camera zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: Schritt 1, Bild 1 von 3 PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: Schritt 1, Bild 2 von 3 PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: Schritt 1, Bild 3 von 3
    • There are two PH0 Screws in the socket which hold the cable.
    • Unscrew two PH0 Screws and pull off the cable holder.
  2. PlayStation 4 Camera Teardown: Schritt 2, Bild 1 von 3 PlayStation 4 Camera Teardown: Schritt 2, Bild 2 von 3 PlayStation 4 Camera Teardown: Schritt 2, Bild 3 von 3
    • The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
  3. PlayStation 4 Camera Teardown: Schritt 3, Bild 1 von 1
    • There is one more PH0 screw to remove. This one is behind the other lens.
    • This was the easy part.
  4. PlayStation 4 Camera Teardown: Schritt 4, Bild 1 von 3 PlayStation 4 Camera Teardown: Schritt 4, Bild 2 von 3 PlayStation 4 Camera Teardown: Schritt 4, Bild 3 von 3
    • There are many clips in there.
  5. PlayStation 4 Camera Teardown: Schritt 5, Bild 1 von 2 PlayStation 4 Camera Teardown: Schritt 5, Bild 2 von 2
    • Encore two photos where to locate these nasty clips
  6. PlayStation 4 Camera Teardown: Schritt 6, Bild 1 von 3 PlayStation 4 Camera Teardown: Schritt 6, Bild 2 von 3 PlayStation 4 Camera Teardown: Schritt 6, Bild 3 von 3
    • The other half of the housing is attached to a solid U-Frame with the electronics.
    • There are four silver screws, PH0.
    • Four microphones, two with black/yellow cables and two with black/red wiring.
  7. PlayStation 4 Camera Teardown: Schritt 7, Bild 1 von 2 PlayStation 4 Camera Teardown: Schritt 7, Bild 2 von 2
    • The backside of the U-frame. The cable is not soldered, there is a plug.
    • Detail of the plug.
  8. PlayStation 4 Camera Teardown: Schritt 8, Bild 1 von 2 PlayStation 4 Camera Teardown: Schritt 8, Bild 2 von 2
    • 6 PH1 screws. Take a small magnet to hold them.
  9. PlayStation 4 Camera Teardown: Schritt 9, Bild 1 von 2 PlayStation 4 Camera Teardown: Schritt 9, Bild 2 von 2
    • The connector of the mikrophone-array
  10. PlayStation 4 Camera Teardown: Schritt 10, Bild 1 von 3 PlayStation 4 Camera Teardown: Schritt 10, Bild 2 von 3 PlayStation 4 Camera Teardown: Schritt 10, Bild 3 von 3
    • The lenses, plastic, glued tight.
    • NOT ADJUSTABLE.
  11. PlayStation 4 Camera Teardown: Schritt 11, Bild 1 von 2 PlayStation 4 Camera Teardown: Schritt 11, Bild 2 von 2
    • Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it.
    • I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
  12. PlayStation 4 Camera Teardown: Schritt 12, Bild 1 von 1
    • Extra: The wiring.
    • It's an USB3 cable without green/white Pimf. There are three SEPARATE ISOLATED metalfoil shields with wire, red-black-power and two Pimf yellow/blue and orange/green. So ja, thats it. Paulaner.
Schwarzstein
2.813 Reputation
13 Anleitungen geschrieben
7 Kommentare
Only 7 steps? Where is the rest of the teardown? I wanted to see detailed images of the optics.
Alexandru Voda - Antwort
Ja, okay, i made some pictures for you. The optics are in Step 10.
Enjoy.
Freundliche Grüsse. :)
Schwarzstein - Antwort
Does anyone think it would be possible to cut the wires from two cameras and splice the wires together and put the power on a A/B rocker switch to switch between two cameras?
Dan Schultz - Antwort
Great job, congrats. Do you have also for the other version of ps4 camera same as this one? BR.
Cosmin - Antwort
I'm wondering if it can even be spliced or soldered back together and actually work
bhee81 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 23
Letzte 30 Tage: 55
Insgesamt: 12,369
