Zum Hauptinhalt wechseln
Sony Vaio PCG-F360 Floppy Drive Replacement
  1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Floppy Drive Replacement: Schritt 2, Bild 1 von 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Floppy Drive Replacement: Schritt 3, Bild 1 von 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Floppy Drive Replacement: Schritt 4, Bild 1 von 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: Schritt 5, Bild 1 von 2 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: Schritt 5, Bild 2 von 2
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
Abschluss
ahintz
28 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 16-3, Maness Spring 2010 Mitglied von Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,757
