Zum Hauptinhalt wechseln
Dell Latitude D600 RAM (Main Memory) Replacement
Was du brauchst
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: Schritt 1, Bild 1 von 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 2, Bild 1 von 2 Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 2, Bild 2 von 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): Schritt 4, Bild 1 von 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): Schritt 4, Bild 2 von 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 5, Bild 1 von 3 Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 5, Bild 2 von 3 Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 5, Bild 3 von 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 6, Bild 1 von 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 7, Bild 1 von 3 Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 7, Bild 2 von 3 Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 7, Bild 3 von 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: Schritt 8, Bild 1 von 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph
1.497 Reputation
5 Anleitungen geschrieben
Ein Kommentar
Almost perfect: easy; clear;
Herman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 22
Insgesamt: 2,845
