Zum Hauptinhalt wechseln
LG VX7000 External LCD Display Replacement
Was du brauchst
  1. LG VX7000 External LCD Display Replacement, External LCD Display: Schritt 1, Bild 1 von 1
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: Schritt 2, Bild 1 von 1
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
Abschluss
Nichole Shaw
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 18-75, Johann Spring 2010 Mitglied von Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,688
