Zum Hauptinhalt wechseln
Disabling DualShock 4's Blue LED
Was du brauchst
  1. Disabling DualShock 4's Blue LED, Disabling DualShock 4's Blue LED: Schritt 1, Bild 1 von 1
    • Remove the four Phillips #00 screws from the back of the controller.
  2. Disabling DualShock 4's Blue LED: Schritt 2, Bild 1 von 1
    • Remove the bottom half of the controller while monitoring the triggers and springs within.
  3. Disabling DualShock 4's Blue LED: Schritt 3, Bild 1 von 1
    • Pull the ribbon cable out of the LED/USB connecter assembly in the center of the controller.
  4. Disabling DualShock 4's Blue LED: Schritt 4, Bild 1 von 2 Disabling DualShock 4's Blue LED: Schritt 4, Bild 2 von 2
    • Place a thin piece of paper in front of the last 2 pins (counting from left to right).
    • The paper will prevent the motherboard from completing the circuit that enables the blue LED.
  5. Disabling DualShock 4's Blue LED: Schritt 5, Bild 1 von 2 Disabling DualShock 4's Blue LED: Schritt 5, Bild 2 von 2
    • Don't twist the ribbon cable when inserting it.
    • Insert back ribbon cable with piece of thin paper already inserted.
    • Connect the bottom half of the DualShock 4 controller together.
    • Rescrew 4 Phillips screws on the back of the controller.
Abschluss
All you have to do now - is embrace the darkness; don't forget to screw the thing back together though :)
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Darie H
4.550 Reputation
5 Anleitungen geschrieben
16 Kommentare
You are using the word "loose" incorrectly.
Loose is an adjective, the opposite of tight or contained.
Lose is a verb that means to suffer the loss of, to miss.
Matt Ferguson - Antwort
*crrrrcth*...."we've got a 10-O-3 in progress, disturbing the English language, requesting grammar assistance"....*crrrrctch*
*crrrrctch*...."roger dispatch, Ferguson en route"....*crrrrtch*
Fuzy Munky -
Yeah, some people actually prefer their guides to look as professional as possible. Correcting someone’s grammar in a guide is meant to help them properly establish their brand. If you prefer to write a guide, Fuzy, with completely broken English (or whichever language you prefer) then you’re free to do so. I’m quite sure many people would second-guess the information within if the grammar is terrible. It’s all about appearance, professionalism, and personal brand.
Robert -
Thanks - now I realised it too :))
Darie H - Antwort
This $@$* &&^& my &&^&^$^ controller up and now I'm mad fickle this $@$*
Mario Avila - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 64
Insgesamt: 30,718
