Zum Hauptinhalt wechseln
IBM ThinkPad 560z Hard Drive Replacement
Was du brauchst
  1. IBM ThinkPad 560z Hard Drive Replacement, Upper Case: Schritt 1, Bild 1 von 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Hard Drive Replacement: Schritt 2, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Hard Drive Replacement: Schritt 3, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Hard Drive Replacement: Schritt 4, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Hard Drive Replacement: Schritt 6, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Hard Drive Replacement: Schritt 8, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Hard Drive Replacement, Hard Disk Drive: Schritt 9, Bild 1 von 1
    • On the back of the computer, use a Flathead screwdriver to remove this lone screw.
  10. IBM ThinkPad 560z Hard Drive Replacement: Schritt 10, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • After the screw is out, gently remove the cover.
  11. IBM ThinkPad 560z Hard Drive Replacement: Schritt 11, Bild 1 von 3 IBM ThinkPad 560z Hard Drive Replacement: Schritt 11, Bild 2 von 3 IBM ThinkPad 560z Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver.
  12. IBM ThinkPad 560z Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Make sure you are grounded and detach the IDA cable connecting the hard disk to the motherboard.
  13. IBM ThinkPad 560z Hard Drive Replacement: Schritt 13, Bild 1 von 2 IBM ThinkPad 560z Hard Drive Replacement: Schritt 13, Bild 2 von 2
    • Remove the final two screws (shown) and slide out the hard drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 26-27, Regan Spring 2010 Mitglied von Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
You don't have to go to this length to remove the hard drive on a 560Z. Only do steps 0 (remove battery), 9 (remove screw) and 10 (remove cover). Then simply grab the blue tab of the hard drive caddy and pull the drive out of the bay. Complete directions on maintenance of the IBM Thinkpad 560Z can be found here:
http://www.thinkpads.com/support/hmm/hmm...
The Hardware Maintenance Manual has all of the information you need to take a 560Z apart and put it back together.
The procedure outlined here is similar to what the 560, 560E and 560X systems required; the 560Z is totally different when removing the hard drive.
Raymond - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 3,829
