Zum Hauptinhalt wechseln
Texas Instruments TI-92 Backup Battery Replacement
Was du brauchst
  1. Texas Instruments TI-92 Backup Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Texas Instruments TI-92 Backup Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Texas Instruments TI-92 Backup Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Backup Battery Replacement: Schritt 2, Bild 1 von 2 Texas Instruments TI-92 Backup Battery Replacement: Schritt 2, Bild 2 von 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Backup Battery Replacement: Schritt 3, Bild 1 von 2 Texas Instruments TI-92 Backup Battery Replacement: Schritt 3, Bild 2 von 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Backup Battery Replacement, Backup Battery: Schritt 4, Bild 1 von 1
    • Before removing the backup battery make sure your AA batteries are installed so that there is no loss of information.
    • Using a #00 Philip Screwdriver remove the 19mm screw located near the center of the back of the calculator on the panel with words "Test Access"
  5. Texas Instruments TI-92 Backup Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the screw and lift the panel to access battery.
  6. Texas Instruments TI-92 Backup Battery Replacement: Schritt 6, Bild 1 von 2 Texas Instruments TI-92 Backup Battery Replacement: Schritt 6, Bild 2 von 2
    • The backup battery can now be seen underneath a small metal cover held by a screw.
    • Using the same screwdriver, unscrew the 4.6mm screw located under the panel and left of the backup battery.
  7. Texas Instruments TI-92 Backup Battery Replacement: Schritt 7, Bild 1 von 3 Texas Instruments TI-92 Backup Battery Replacement: Schritt 7, Bild 2 von 3 Texas Instruments TI-92 Backup Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the metal cover keeping the backup battery in place.
  8. Texas Instruments TI-92 Backup Battery Replacement: Schritt 8, Bild 1 von 2 Texas Instruments TI-92 Backup Battery Replacement: Schritt 8, Bild 2 von 2
    • Use an Ipod Opening Tool or a similar tool to pull up on the right side of the backup battery.
    • The battery should pop out of position.
  9. Texas Instruments TI-92 Backup Battery Replacement: Schritt 9, Bild 1 von 2 Texas Instruments TI-92 Backup Battery Replacement: Schritt 9, Bild 2 von 2
    • After the battery has been tilted out of its socket, simply remove it with your hands.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 15-51, Garner Spring 2010 Mitglied von Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 5,094
