Zum Hauptinhalt wechseln
Disassembling Nokia 3560 Vibrator
Was du brauchst
  1. Disassembling Nokia 3560 Vibrator, Back Cover: Schritt 1, Bild 1 von 2 Disassembling Nokia 3560 Vibrator, Back Cover: Schritt 1, Bild 2 von 2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Keypad: Schritt 2, Bild 1 von 1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Vibrator: Schritt 3, Bild 1 von 2 Disassembling Nokia 3560 Vibrator: Schritt 3, Bild 2 von 2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 LCD Display: Schritt 4, Bild 1 von 1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Vibrator: Schritt 5, Bild 1 von 1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Vibrator: Schritt 6, Bild 1 von 2 Disassembling Nokia 3560 Vibrator: Schritt 6, Bild 2 von 2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Vibrator: Schritt 7, Bild 1 von 1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Logic Board: Schritt 8, Bild 1 von 1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: Schritt 9, Bild 1 von 2 Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: Schritt 9, Bild 2 von 2
    • The orange piece is the vibrator.
    • It is not fastened by any means.
    • Remove with tweezers.
Abschluss
Sam Ryan
1 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 30-39, Garner Spring 2010 Mitglied von Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,261
