Zum Hauptinhalt wechseln
Disassembling Nokia 3395 Logic Board
Was du brauchst
  1. Disassembling Nokia 3395 Logic Board, Back Case: Schritt 1, Bild 1 von 3 Disassembling Nokia 3395 Logic Board, Back Case: Schritt 1, Bild 2 von 3 Disassembling Nokia 3395 Logic Board, Back Case: Schritt 1, Bild 3 von 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: Schritt 2, Bild 1 von 2 Disassembling Nokia 3395 Logic Board, Battery: Schritt 2, Bild 2 von 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: Schritt 3, Bild 1 von 2 Disassembling Nokia 3395 Logic Board, Front Case: Schritt 3, Bild 2 von 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: Schritt 4, Bild 1 von 2 Disassembling Nokia 3395 Logic Board, Screen: Schritt 4, Bild 2 von 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: Schritt 5, Bild 1 von 2 Disassembling Nokia 3395 Logic Board: Schritt 5, Bild 2 von 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: Schritt 6, Bild 1 von 2 Disassembling Nokia 3395 Logic Board, Logic Board: Schritt 6, Bild 2 von 2
    • Remove logic board as shown.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nico Lee
78 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 30-41, Garner Spring 2010 Mitglied von Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,878
