Zum Hauptinhalt wechseln
Samsung L100 flash assembly replacement
Was du brauchst
  1. Samsung L100 flash assembly replacement, Removing Back Cover: Schritt 1, Bild 1 von 3 Samsung L100 flash assembly replacement, Removing Back Cover: Schritt 1, Bild 2 von 3 Samsung L100 flash assembly replacement, Removing Back Cover: Schritt 1, Bild 3 von 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 flash assembly replacement: Schritt 2, Bild 1 von 2 Samsung L100 flash assembly replacement: Schritt 2, Bild 2 von 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 flash assembly replacement: Schritt 3, Bild 1 von 3 Samsung L100 flash assembly replacement: Schritt 3, Bild 2 von 3 Samsung L100 flash assembly replacement: Schritt 3, Bild 3 von 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 flash assembly replacement: Schritt 4, Bild 1 von 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 flash assembly replacement: Schritt 5, Bild 1 von 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 flash assembly replacement, Flash Circuit Board: Schritt 6, Bild 1 von 1
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  7. Samsung L100 flash assembly replacement: Schritt 7, Bild 1 von 2 Samsung L100 flash assembly replacement: Schritt 7, Bild 2 von 2
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  8. Samsung L100 flash assembly replacement: Schritt 8, Bild 1 von 1
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  9. Samsung L100 flash assembly replacement: Schritt 9, Bild 1 von 1
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  10. Samsung L100 flash assembly replacement: Schritt 10, Bild 1 von 3 Samsung L100 flash assembly replacement: Schritt 10, Bild 2 von 3 Samsung L100 flash assembly replacement: Schritt 10, Bild 3 von 3
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adriel
123 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-17, Maness Spring 2010 Mitglied von Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 4,019
