Zum Hauptinhalt wechseln
Disassembling Nokia 6086 Top Front Cover
Was du brauchst
  1. Disassembling Nokia 6086 Top Front Cover, Battery: Schritt 1, Bild 1 von 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Top Front Cover: Schritt 2, Bild 1 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 2, Bild 2 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 2, Bild 3 von 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Top Front Cover: Schritt 3, Bild 1 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 3, Bild 2 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 3, Bild 3 von 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: Schritt 4, Bild 1 von 1
    • Close the phone.
    • Face the front cover forward.
  5. Disassembling Nokia 6086 Top Front Cover: Schritt 5, Bild 1 von 2 Disassembling Nokia 6086 Top Front Cover: Schritt 5, Bild 2 von 2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Disassembling Nokia 6086 Top Front Cover: Schritt 6, Bild 1 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 6, Bild 2 von 3 Disassembling Nokia 6086 Top Front Cover: Schritt 6, Bild 3 von 3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrea
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 26-30, Regan Spring 2010 Mitglied von Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 2,217
