Einleitung
This guide is a step by step process to remove the top cover of the phone. It is the preliminary step, in order to gain access into the upper section of the phone.
Was du brauchst
Turn off the phone.
Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
Position the phone so that the back side is in view.
Remove the back battery cover.
Apply pressure on the cover while simultaneously sliding the cover downward.
Insert the iPod opening tool between the base of the phone and the phone battery.
Position the phone so that the battery won't fall out of the phone.
Carefully lift the battery out of the phone.
Locate the 4.5 mm notch at the top of the phone.
Place the iPod opening tool into the opening.
Slightly prop up the top section by lifting the tool.
Wedge the iPod opening tool between the top cover and the phone.
Gently lift the top cover away from the phone using the iPod opening tool.
This unlatches each hook that connects the top cover to the phone.
Place the top cover aside once the top cover is completely disconnected from the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
