Einleitung
This guide will assist you in removing the vibration motor from your Sony Ericsson T68i.
Was du brauchst
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
