Zum Hauptinhalt wechseln
Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: Schritt 2, Bild 1 von 1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: Schritt 4, Bild 1 von 1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: Schritt 5, Bild 1 von 3 Sony Vaio PCG-981L Battery Replacement: Schritt 5, Bild 2 von 3 Sony Vaio PCG-981L Battery Replacement: Schritt 5, Bild 3 von 3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: Schritt 6, Bild 1 von 2 Sony Vaio PCG-981L Battery Replacement: Schritt 6, Bild 2 von 2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
Abschluss
Enjoy your new battery.
Cal Poly, Team 18-68, Johann Spring 2010 Mitglied von Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 3,802
