Zum Hauptinhalt wechseln
Disassembling the Nokia 6300
Was du brauchst
  1. Disassembling the Nokia 6300, Rear Cover: Schritt 1, Bild 1 von 1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: Schritt 2, Bild 1 von 2 Disassembling the Nokia 6300: Schritt 2, Bild 2 von 2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: Schritt 3, Bild 1 von 1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: Schritt 4, Bild 1 von 1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: Schritt 5, Bild 1 von 1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: Schritt 6, Bild 1 von 3 Disassembling the Nokia 6300: Schritt 6, Bild 2 von 3 Disassembling the Nokia 6300: Schritt 6, Bild 3 von 3
    • There's your phone!
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
LucasJV
735 Reputation
3 Anleitungen geschrieben
Verheij.co Mitglied von Verheij.co
Business
1 Mitglied
5 Anleitungen geschrieben
Ein Kommentar
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 23,680
