Zum Hauptinhalt wechseln
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
Was du brauchst
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 2, Bild 1 von 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 3, Bild 1 von 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: Schritt 4, Bild 1 von 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: Schritt 4, Bild 2 von 2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 5, Bild 1 von 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 5, Bild 2 von 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 5, Bild 3 von 3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: Schritt 6, Bild 1 von 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: Schritt 6, Bild 2 von 2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 7, Bild 1 von 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 7, Bild 2 von 2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: Schritt 8, Bild 1 von 1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
donnavon
707 Reputation
7 Anleitungen geschrieben
Pasco Hernando, Team 1-1, Prince Fall 2014 Mitglied von Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
What Cpu does it use?
Jazelle Estrada - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 2,146
