Einleitung
Looking to replace your original CPU with faster yet compatible one? Or are you just replacing a faulty one? This guide will walk you through replacing your existing CPU with a newer one.
Was du brauchst
Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Lay the computer on its side; you will see a blue knob.
Turn said knob 90 degrees counter clockwise.
While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
Pull back on the tab nearest to the front case fan.
Slide the CPU heat sink from under the clip and pull upward.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
