Zum Hauptinhalt wechseln
Toshiba Satellite C655D-S5200 LCD Replacement
Was du brauchst
  1. Toshiba Satellite C655D-S5200 LCD Replacement, LCD: Schritt 1, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: Schritt 1, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: Schritt 1, Bild 3 von 3
    • Here is the Toshiba Satellite C655D-S5200
    • Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner
    • Removing the plugs reveal the Phillips screws
  2. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 2, Bild 3 von 3
    • Remove all four screws, tow on top left and right corner
    • One on the bottom left corner
    • and the bottom right corner.
    • Here are the four M3x5mm screws
  3. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
    • Continue to slide the tool all the way across the top
    • Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
  4. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 4, Bild 3 von 3
    • Continue to pull gently on the sides
    • and finally on the bottom.
    • With all the tabs released the bezel can now be removed.
  5. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 5, Bild 3 von 3
    • Here is the LCD assembly without the bezel
    • Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
    • Remove the right one as well
  6. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 6, Bild 3 von 3
    • The LCD can now be moved forward and away from the rear cover
    • There are three screws on either side that hold the panel to the frame. Remove those
    • Here are the three M2x4 screws
  7. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 7, Bild 3 von 3
    • Remove the three Phillips screws on the right side as well.
    • with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable.
    • The display cable is secured to the connector with some clear adhesive. Remove this frist
  8. Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite C655D-S5200 LCD Replacement: Schritt 8, Bild 2 von 2
    • Remove the display cable carefully.
    • With the display cable disconnected, the LCD can now be removed and replaced.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
oldturkey03
782.133 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
537 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,507
