Zum Hauptinhalt wechseln
BlackBerry 7100g Motherboard Replacement
Was du brauchst
  1. BlackBerry 7100g Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Motherboard Replacement: Schritt 2, Bild 1 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 2, Bild 2 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Motherboard Replacement, Housing: Schritt 4, Bild 1 von 3 BlackBerry 7100g Motherboard Replacement, Housing: Schritt 4, Bild 2 von 3 BlackBerry 7100g Motherboard Replacement, Housing: Schritt 4, Bild 3 von 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Motherboard Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7100g Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Motherboard Replacement: Schritt 6, Bild 1 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 6, Bild 2 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 6, Bild 3 von 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Motherboard Replacement: Schritt 7, Bild 1 von 1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Motherboard Replacement, Battery Housing / Speaker: Schritt 8, Bild 1 von 2 BlackBerry 7100g Motherboard Replacement, Battery Housing / Speaker: Schritt 8, Bild 2 von 2
    • Turn over the motherboard so that the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
  9. BlackBerry 7100g Motherboard Replacement: Schritt 9, Bild 1 von 2 BlackBerry 7100g Motherboard Replacement: Schritt 9, Bild 2 von 2
    • The battery terminal is separate from the battery housing.
    • Do NOT get rid of the terminal if replacing the battery housing and/or the speaker.
    • The terminal will slide out of the housing.
  10. BlackBerry 7100g Motherboard Replacement, Keypad: Schritt 10, Bild 1 von 3 BlackBerry 7100g Motherboard Replacement, Keypad: Schritt 10, Bild 2 von 3 BlackBerry 7100g Motherboard Replacement, Keypad: Schritt 10, Bild 3 von 3
    • Turn the "guts" over so the speaker is facing up.
    • Separate the battery housing from the motherboard.
  11. BlackBerry 7100g Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
  12. BlackBerry 7100g Motherboard Replacement, Screen: Schritt 12, Bild 1 von 2 BlackBerry 7100g Motherboard Replacement, Screen: Schritt 12, Bild 2 von 2
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
  13. BlackBerry 7100g Motherboard Replacement: Schritt 13, Bild 1 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 13, Bild 2 von 3 BlackBerry 7100g Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
  14. BlackBerry 7100g Motherboard Replacement, Motherboard: Schritt 14, Bild 1 von 2 BlackBerry 7100g Motherboard Replacement, Motherboard: Schritt 14, Bild 2 von 2
    • You have successfully removed the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 25-87, Amido Spring 2010 Mitglied von Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 2,054
