Zum Hauptinhalt wechseln
Motorola Droid Motherboard Replacement
Was du brauchst
  1. Motorola Droid Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola Droid Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola Droid Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Motherboard Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Motherboard Replacement: Schritt 4, Bild 1 von 2 Motorola Droid Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Motherboard Replacement: Schritt 5, Bild 1 von 2 Motorola Droid Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Motherboard Replacement: Schritt 10, Bild 1 von 2 Motorola Droid Motherboard Replacement: Schritt 10, Bild 2 von 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Motherboard Replacement: Schritt 11, Bild 1 von 2 Motorola Droid Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
  12. Motorola Droid Motherboard Replacement, Speaker: Schritt 12, Bild 1 von 1
    • Carefully lift and remove the speaker assembly up out of the phone.
  13. Motorola Droid Motherboard Replacement, Motherboard: Schritt 13, Bild 1 von 3 Motorola Droid Motherboard Replacement, Motherboard: Schritt 13, Bild 2 von 3 Motorola Droid Motherboard Replacement, Motherboard: Schritt 13, Bild 3 von 3
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  14. Motorola Droid Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
  15. Motorola Droid Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  16. Motorola Droid Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  17. Motorola Droid Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Motorola Droid Motherboard Replacement: Schritt 18, Bild 1 von 2 Motorola Droid Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the phone.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Brett Hartt
127.876 Reputation
143 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.732 Anleitungen geschrieben
Ein Kommentar
Hi all,
Can anyone please suggest me should I dump my motorola droid. I have taken it to fix-it shops and they all have the same answer the mother board is gone
So, is it better to buy a new mother board which would cost me as much as a new phone or just sell it for nickels on Ebay
please reply pbansal1@jhu.edu
prateek - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 28,985
