Einleitung
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Was du brauchst
Einführungsvideo
Switch-off the tablet.
Use a cutter and a plastic tool to remove the back cover.
Disconnect the battery connector.
The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
Li-on Batteri Pack, 3.8V, 2640mAh
Did you do it successfully?
3 weitere Nutzer:innen haben diese Anleitung absolviert.
