Zum Hauptinhalt wechseln
Sony Walkman WM-AF48 Headphone Jack Replacement
Was du brauchst
  1. Sony Walkman WM-AF48 Headphone Jack Replacement, Getting started: Schritt 1, Bild 1 von 1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: Schritt 2, Bild 1 von 3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: Schritt 2, Bild 2 von 3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: Schritt 2, Bild 3 von 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: Schritt 3, Bild 1 von 2 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: Schritt 3, Bild 2 von 2
    • Gently pull the ribbon from the jack just above the film revolver, near the edge.
    • Carefully lift the motherboard out of the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
  4. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the headphone jack: Schritt 4, Bild 1 von 1
    • Locate the four metal points on the motherboard that hold the headphone jack in place.
    • Using a soldering iron, remove the headphone jack by de-soldering the four points that hold it in place.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 30
Insgesamt: 5,535
